Ford 2000 Skipping popping
Fred Pevey
I have a 1969 Ford 2000 w/3 cyl engine. It only cranks with the accelerator on idle, and it skips and pops when accelerated and under load.
Runs good for a while and then it skips and pops.
Will a weak battery cause this?
I had a spark plug wire pop off of mine last weekend. I had put a new set of plugs in and 1 was not tight. after running it hard I heard a pop followed by intermittent poor preformance.
Tightened the plug and put the wire back on, good to go
Fred:
The symptoms that you describe are not caused by a weak battery.
Most likely the starting problem is caused by a mis adjusted choke cable that does not fully close the choke valve.
The missing upon acceleration can be caused by either ignition or carburetion problems.
Dean
Fred:
Dean
