Ford 2000 Starter
eagle24
1963 Ford 2000 gas burner. May have multiple issues. The starter would sometimes drag and smoke. Other times, it would turn over fine and run. I got it cranked Saturday and was doing some dirt work with a box blade, ran it about 30 minutes and all the sudden it shut off like I had turned the switch off. Definitely lost fire. I took a lunch break and tried to crank it, starter dragged and smoked. Took the starter off and carried it to the auto parts to have it tested. It spun fine when they tested it, but started smoking after about 3 seconds. Putting a new starter on this afternoon, but thinking I still have an issue that caused the tractor to shut off, or could the short in the starter have caused this as well? Thought about getting a coil and voltage regulator so I would have them if I needed them after I install the starter.
coil and vreg?
might as well just buy a new spare tractor if all you are gonna do is throw parts at it without troubleshooting any.
starter was bad.
could have made the solenoid stick, and that could be a big short / electrical load.
next time it stalls.. check spark. if it has none, hhotwire the coil and go from there.
soundguy
Wasn"t planning to throw parts at it without checking. I just wanted some input on whether I may have multiple unrelated issues, or the starter could be causing all the problems. If I don"t take a coil and vr home with me this evening, I"m done for tonight if it turns out I need either. I can take them both back tomorrow if I don"t need them.
a vreg huh..
are you having charging problems?
you can remove the vreg and genny and throw then as far as you can out in the field and still start that tractor and run it.. it just won't cool or charge... the vreg has positively NOTHING directly to do with the ignition.
had you made a simple spark test you wouldn't have to buy a coil to take home just as insurance.
your money and call on that one though.
soundguy
If you're going to buy a coil and vr "in case you need them" you may as well go ahead and buy a new key switch, points, condenser and rotor. They can all cause the engine to not run.
yep.. with no diagnostics, he's in for a pound if he's in for a penny if he merely wants parts setting on the shelf for insurance.
soundguy
Look, I just asked a question which has not been answered. I don't claim to be a tractor mechanic, just need some dirt work done and the tractor isn't cooperating. I was trying to ask if the short in the starter could affect anything and cause the ignition issues I am having. Regarding the coil and vr, I work next door to the auto part store and have an account there. I could take a coil and vr home and if I need them I will have them. If I don't take them home and I need them, I am out of luck till tomorrow. I have checked all the wiring connections and the points (to make sure the screw didn't come loose). All the plug wires and coil wire are less than a couple of years old. Switch is a definite possibility of the issue. I took it out and cleaned it with contact cleaner last summer when it gave me trouble. As for the VR, I thought if you unhooked the battery an engine with a generator and VR would still run??? and I was under the impression that the voltage to the coil was regulated. And yes, I have a charging problem or either the short in the starter is draining the battery. Sorry I came here for help. I misunderstood what this forum was for I guess.
(quoted from post at 14:12:31 06/13/11) Look, I just asked a question which has not been answered. I don't claim to be a tractor mechanic, just need some dirt work done and the tractor isn't cooperating. I was trying to ask if the short in the starter could affect anything and cause the ignition issues I am having. Regarding the coil and vr, I work next door to the auto part store and have an account there. I could take a coil and vr home and if I need them I will have them. If I don't take them home and I need them, I am out of luck till tomorrow. I have checked all the wiring connections and the points (to make sure the screw didn't come loose). All the plug wires and coil wire are less than a couple of years old. Switch is a definite possibility of the issue. I took it out and cleaned it with contact cleaner last summer when it gave me trouble. As for the VR, I thought if you unhooked the battery an engine with a generator and VR would still run??? and I was under the impression that the voltage to the coil was regulated. And yes, I have a charging problem or either the short in the starter is draining the battery. Sorry I came here for help. I misunderstood what this forum was for I guess.
on't feel singled out........As an estimate, I would say that as a minimum, 65% of responses are to a question that wasn't asked, without a direct answer to the actual question asked. You might think that we are a bunch of congressmen or President, mightn't you? :(
No, a bad starter alone will not drain the battery, since it is only connected when you command start (via solenoid). Yes with old fashioned gen/mechanical VR, it will keep running & regulate when battery cable disconnected. With anything solid state such as modern alternators, such disconnection is a gamble, as the resulting transient voltage may destroy SS devices.
i answered your question in my first reply.
since you want to be sarcastic.. you can now fix it by yourself.. I will no longer respond to your posts.
voltage to the coil regulated? it's a 6v tractor with a 6v battery and 6v to the coil. that's about as 'regulated' as it gets.
no more replies from me...
Actually.. if he re-reads my very first response he will find out I did indeed answer his question re the starter.. though it involved a sticcking solenoid in my theory.
soundguy
Thanks. The starter motor is definitely bad. It appears to me that I have an unrelated problem regarding the ignition. With the wires unhooked, the switch measures continuity in the run position and the run/lights position, but it gave me problems a year ago and seems really sloppy. I traced all the wires and cleaned a few connections. Points and gap look good. Points and condensor were replaced less than a year ago. Plug and coil wires appear in good condition. Can't a coil quit working when it gets hot? any suggestions on anything else that might have killed the ignition fire? Also, I noticed while it was running at near idle the amp meter showed very slight to the + side. At about 1000 rpm's it pegged +30, is that normal?
Does it have a true 12V coil (marked No Resistor Needed) or is it a 6V coil with a resistor in the wire between the switch and the coil?
Not sure, will have to look. I bought the tractor about 6 years ago and all I can tell you is it had a 12v battery when I got it and I have used it for the last 6 years. All I have done is replaced the points, plugs, and condensor a couple of times. Leaks a little oil and burns a little, but runs strong with good pressure. Also, the starter doesn't have a solenoid. It has a mechanical type bendix.
look behind your air cleaner.. that's wher ethe starter relay is hiding.
different animal entirely than a mechanical bendix.
answers like that aren't gonna net you any more help..
we know FULL well what the starter is equipped with on that model. you may not be familiar with those tractors.. but don't assume we don't know about them...
soudnguy
I"ll be the first to admit I"m not a mechanic. I"m trying to give whatever info I can to get some help and trying to understand the responses. I certainly didn"t intend to imply you don"t know what the starter is on my model tractor. It is more likely I am having trouble asking the right questions and giving the right info. As for the solenoid, yes it is behind the air cleaner mounted to the battery box. I thought it was a VR. The generator is actually an alternator. The coil says "For use with an external resistor" and "12V". The wire runs through a ceramic terminal block that (I think) may be the resistor. What I was trying to ask in my original post (and understand in your original reply) is whether I have multiple problems or the starter could be causing all the problems.
First thing I would do is to buy a true 12V coil marked "No Resistor Needed" and get rid of the ceramic resistor.
Yes, the starter can cause the engine to not run. If (as Soundguy told you in his original response) the starter solenoid gets stuck in the closed position sending lots of juice to the starter there will be no juice left to fire the coil. However you said that the engine had been running for 30 minutes when it quit dead as a doornail. If it had been running for 30 minutes with the solenoid stuck closed your starter would have been red hot so it is highly unlikely that your solenoid was stuck closed. I'm betting that either your key switch lost contact or your resistor burned up.
Since you are putting on a new starter I would go ahead and put on a new solenoid. Tell your parts guy that you need a replacement for a Ford 311006. DO NOT take him your old one and tell him you need one that "looks like this one". I guarantee you will get the wrong one and then you will have more problems.
ditto what awhtx said.
get a correct coil.. a napa ic14sb true 12v coil, and loose the resistor.
run power to the new coil bypassing the key switch.. if it runs, check the key switch it is likely bad.. that or that resistor went bad. I doubt that 6v coil is bad.. but it's better to use a 12v coil if you have an alternator.
soundguy
