If I remember right it was new to be 12 volt negative groundI have a Ford 2000 that I recently purchased. It has been sitting up for a little while and does not I have a battery in it. I am thinking it is a 6 volt but may need a 12 volt. The serial number is a C255272. Not sure of the year. Would like to learn more about it.
For the 2000 tractors the generators might have been positive ground originally and alternators were negative ground.Generators are positive ground, alternators are negative ground
According to the serial number your 2000 is a 69 model, all Ford tractors from 65-75 except the 7000 model were 12 volt negative ground with generatorsHello DW, welcome to YT. Per the link Tractordata shows it could be either 6 volt positive ground or 12 volt negative ground. Ford 2000 on tractordata Pull out a headlight and see what voltage it says. I sure there are Ford guys on here that can tell you which it was originally by the SN. Also it’s a 1963. Both the SN number info and battery info are down low on that linked page.
