(quoted from post at 06:25:40 04/17/23)
(quoted from post at 06:52:30 04/17/23)
(quoted from post at 18:46:20 04/16/23)
Do some testing before buying anymore parts.
Yes, let s step back
1. Let s start by testing the key switch
Here is what about have:
A three position switch witch four wires.
- wire from battery and to light
This wire always has 12 v
- wire to start solenoid and to safety gear
This wire has 12 v when in "start" position
- wire to instrument panel
- wire to voltage regulator
These wires have continuity in "run" position
I would like to understand what happens when the switch is in "run" position so I can test all the connections.
What I mean what should happen when I turn the key to "run" position so the tractor can run?
Thanks again for all your help
All wires should have continuity from one end to the other regardless of what position the key switch is in, so your point about the wires to the instrument cluster and the VR having continuity when the key switch is in the run position tells us nothing other than those two wires are not broken. They should have continuity when the key switch is in the off position also, as well as in the start position. If you meant to say that they have 12 volts when in the run position, then the key switch is operating correctly in the run position. Without a voltage reading on those wires when the key is in the run position, we cannot tell you whether the switch is working properly in the run position or not.
You do not mention a wire from the run position of the key switch to the coil, and whether that wire has a resistance wire (fat section of wire inside of heat shrink) or a ballast resistor in-line with it, so it sounds like that wire is completely missing. It is one of the two wires I mentioned in my original reply.
Trace the wires from the two small posts of the coil. One of those posts should have a single wire going to the distributor. The other small post should have two wires connected, one going to the solenoid and the other going back to the key switch. Depending on what has been done to it over the years, that wire may have the original resistance wire section in it, or it may have a ceramic ballast resistor in-line with it, or if the coil was replaced at some point with a 12 volt coil that requires no external resistor, then the wire may go straight to the key switch, but from your description above, that wire is not connected to the key switch at all. The wire from the solenoid to the coil only provides 12 volts to the ignition circuit when the key is in the start position. Without that second wire, the coil will not have power once you let the key drop back to the run position.
[b:47b573d014]Yes, you are right!!!that's the wire that is missing. From the coil to the key switch...How did it work before??? let me go and check in case I missing something.
Thank you again.[/b:47b573d014]
update. I found the wire that goes from the coil to the key...it was the same wire that went to the voltage regulator...now i have to trace that wire to see where is the problem...Now the electric system makes sense...I will go again tonight to see if I found where is the problem with that wire. Thank you so much!!!
I think I have found the faulty cable...now i need get and get some connectors and see how that goes.
