Ford 2110 hydraulic issues
Paul1184
Just purchased a Ford 2110 with kelly loader and backhoe everything runs fine except three point lift does nothing when i move the leaver. Is there something i am missing, does the backhoe being connected stop the Three point ram from being operational or do i need to get inside and fix seals and gaskets under the seat.
Thank you.
Hard to tell from here, you're looking at it, we're not. I can't help but think the backhoe plumbing is a factor here. Lots of ways to do that, some work better than others. More than likely the lift is just out of the loop right now.
It is quite common for the backhoe return line to go direct to sump instead of looping back to the hydraulic block to feed the three point hitch as there is no need for the three point hitch to work with the backhoe on. We would need to see how the hoses are routed to be able to tell.
The return looks like it goes into the sump low down below the seat. I could send a couple of pics in the morning. I never had a backhoe so all this is very confusing.
