Jmueller
Hi guys, thanks for the add. So I have this Ford 2110 1990 model I believe. I had it for 5 years now. Wanting to put rear remotes on it for a disc. From what I found I just remove the plugs from the auxiliary ports by the seat and run line to the rear? And this is supposedly controlled by the upper notched on the position control lever? So only at the top notch oil is supplied. Does the draft lever control anything then or not? The manual only mentions one port but there is two. Any help is appreciated.
