TerryB IL
I found a 1976 Ford 2600, 1310 hours, original paint, faded but in great shape, tires 90%, 3 cylinder deisel motor. It is a one owner tractor. This tractor has been taken care of. What is a tractor like this worth? Any comments about a 2600 will be appreciated, good or bad.
I currently have a 1952 8n and want to move up a bit in horsepower and hydraulics and pto.
It's going to price out like a similar 2000/3000 3cyl tractor.
it will have slightly updated hyds.
Figure 3500-4000-5000$ as a range.
soundguy
I paid around 3500 for mine, its a gasser, 1100 hours, new front tires, rears ok but getting tired, power steering, paint not great, and a working front end loader. After having mine for 9 months I think I paid a little too much for it as I'm currentl currently re-wiring it, and replacing some seals in the power steering. I think its a solid machine but like many suffered from neglect. Seems a lot of owners do nothing as long as they start and run.
You might check to see if the gauge cluster is working, its a little spendy. Also ask if its ever leaked power steering fluid out from under the steering wheel, not a big deal but may want to ask.
By the time the 26/3600s came out most of them were coming from the factory with LPTO and PS. I'm assuming you have both?
The 2600 was a significant upgrade over the 2000.
It's more like a 3600 with heavier square rear axles, diff lock, etc plus twice the hyd output. About the only difference between the 26 and 36 is flow control and a few less HP. Possibly a lighter front bolster.
It is an excellent series - one of the best Ford ever built. They will eat an 8N's lunch and a Jubilee's desert. The steering seal is NBD IMO.
Just did one for a friend last week - half a Saturday and $20 in parts.
As to value, I'd say start at $4K and go up to $5.5K Yours may reach the higher end with the diesel, very low hours and good rubber.
Let us know what you do. Pics are always welcome.
It does have power steering. He is asking 6500.00 and I thought that was too high. It is a very nice tractor but I just dont think it is worth the asking price.
john, hobo said you could help me with my power steering on my 3000[2600 aparently the same] any photos or any tech tips on how to remove the steering shaft from the case would be appreciated.goin through it to replace all seals and o-rings,also the steering shaft needs polishing.i have the colume loose but can't remove it from the case.can you help me out?hobo said you had posted this already,but i can't find it...thank you,scott king 67'ford 3000
