mikewood869
Anyone know if the transmission and rear end have a common sump where hydraulic fluid would flow from the trans to the rear end or vice versa? I did a fluid change and dump 13 gallons in the rear end and I m going to see in the morning if any of the fluid flowed to the dipstick in the transmission or if I m going to need to drain the oil and dump the oil into the transmission. There s a dipstick on the transmission, but no plugs in the usually spots to check for the oil level. There s two fill plugs (transmission has a plug with breather and rear end is just a plug. I know that our 6610 share the same oil in both sections but not our 4110 or 4500. My 2910 has the 8x4 transmission and is a series 2
