lastcowboy32
Good morning, people.
So, I rebuilt the brakes on my 2N. All new hardware, springs and such. The adjusters are turning freely and lubricated.
I wanted to adjust the brakes and the clutch, so that the tractor shifts and brakes the way its intended.
Part of that process was getting the left brake to actuate at approximately the same pedal depth as the clutch, since they are on the same side and share the brake actuator shaft...which is only a pivot for the clutch pedal.
Here is the issue, I noticed that my clutch pedal could be pressed maybe an inch or so, before any resistance was felt.
I had the tractor on jack stands, and my son-in-law was helping me to test by either pressing the pedals or rolling the tires.
If the tractor was in gear, the clutch pedal could be pushed through this "play" distance without disengaging the tranny at all. The tires were still locked in place, if the tractor was in gear and no brake was applied.
The thing is, this made it so that the clutch had to be pressed all of the way to the floorboard to shift the tranny or the PTO. The tractor has always been like this for the five years that I've had it. We have just "worked around" it by only using the right brake when clutching/shifting. That way, we could push the clutch right to the floorboard.
I wanted to tighten the clutch pedal to bring it up to it's stop. But the linkage adjustment was out of threads. I took it off and added about a half inch of threads with a threading die.
At this point, I could bring the pedal up so that it was just barely rubbing the stop...or just barely missing it.
Then I had my son-in-law get on the tractor and I adjusted the left brake until...
With the tractor in gear and on blocks...
The tires would roll freely if he only pressed the clutch.
The tires would not roll freely if he pressed the clutch and brake together, but he was still able to shift.
I had him take the tractor out for a short drive. He's new to the tractor, so I figured he would be a good guinea pig. He hasn't learned all of the adaptations that I have over the years for shifting it.
I instructed him to shift numerous times, while pressing the clutch and brake simultaneously. I had him do it on a hill, on the flat, numerous times. I also had him engage/disengage the PTO while pushing the clutch and brake.
We seemed to have good adjustment. The tractor would stop from the clutch/brake action. It would shift. It would not roll until the clutch and brake were let up.
Seems good.
BUT...to do this, I had to take what I'm calling "free play" out of the clutch pedal. It makes me anxious. Where would this play come from, and why would I have to add threads to the linkage adjustment to shorten the linkage shorter than the factory intended.
Furthermore...why, after doing this, would the clutch seem to work perfectly. It engages/disengages at matched pedal depth with the brake. It feels like it's engaging fully when let up, especially as evidenced by the multiple spin-outs done by my son-in-law letting it up a little fast. There's no slippage, that I can see.
So...do these pedals sometimes develop a little "play" over 76 years?
Seems good.
