Ford 2N generator
FWB in SK
Generator on tractor not working.This is a one wire generator. Took of polished armature, new brushes. Before put it on checked to see if it would motor. Motored good. Put back on tractor. Started up genny discharged 15 amps.. Remembered when I motored genny I had it grounded with negative and positive for hot wire. Tractor has positive ground. How do I fix this so it charges properly. Any help
appreciated.
I'm NOT a Ford man (ask the Ford experts, do as they tell you) but far as I know on that genny you would polarize it BEFORE starting up, by using a jumper wire to momentarily flash/jump from a hot UNgrounded battery post (that would be the - post on a + grounded tractor) voltage source to the gennys terminal.
John T
(quoted from post at 08:57:53 04/15/20) I'm NOT a Ford man (ask the Ford experts, do as they tell you) but far as I know on that genny you would polarize it BEFORE starting up, by using a jumper wire to momentarily flash/jump from a hot UNgrounded battery post (that would be the - post on a + grounded tractor) voltage source to the gennys terminal.
John T
ep
PS If alls wired right in place an working, the Output side of a cutout relay serves as a hot Ungrounded battery post voltage source sooooooooo jump across it over to the gennys output post should do the trick.
Ask the Ford men to be safe
John T
A one wire design should polarize when flashed as John T indicates. There is a internal connection from the outside terminal to the field, and from the field windings to ground. I would flash it about 5 times in a row with just momentary contact each time. A one wire is usually pretty modest in output, and resistant to polarization. Jim
Thanks Professor, although not a Ford man that's how I thought those one terminal old Ford gennys operated. The Field coils AFTER passing from the ARM terminal to and through both coils were then internally grounded..They were relatively low output and didn't use any variable resistance to ground field current regulation, just always dead ground.
Take care be safe
John T
