ford 2n hydralic pump
ford 5600
Does all ford 2n hydralic knock a little when hot? i used it this evening and the pump knock a little bit louder than it usualy does. i guess this is normal? the fluid levels are all full and i just replaced it in the fall of 08. i guess its an age thing
(quoted from post at 17:50:30 04/29/09) Does all ford 2n hydralic knock a little when hot? i used it this evening and the pump knock a little bit louder than it usualy does. i guess this is normal? the fluid levels are all full and i just replaced it in the fall of 08. i guess its an age thing
As long as it works, keep the faith, and the beat.
That does not mean that I expect it to fail.
My 8N has done that for 25+ years.
Ditto what Dunk said.. these scotch yoke pumps knock a bit when worn.. and knock more the more wear they get.. worry not about the knock.. but worry when she stops knocking. ;)
If you use UTF oil in her.. switch to 90wt gl1 gear lube.. or 80w90 gl4/5 gear lube tht is yellow metal safe.
soundguy
