Anonymous-0
OK I was doing some blading today without any problems. I heard a squealing noise and the blade was lifting slow. I checked the tran/fluid and it was very very low. I filled it up and tried to lift the blade ,,,it did but when I took my foot off the clutch it dropped down slow???? Normally it would stay and I would go into 1st and drop it down as I got into position. very weird, I could not get it to hold in neutral. I asked a guy and he said dimething about a spring ?? or valve , Does anyone know what it could be a how to fix this????????????
Could be a valve or it could also be a bad cylinder seal. Easy way to check is to remove the dip stick cover on the right side and have a look see to see if you see fluid movement in side with the tractor running and the lift in the up position. If you see fluid dripping or other wise moving that is the area your problem is in. The I-T FO4 manual has a good bit of info on it
