Ford 3000 front loader very touchy
chrisb62
Hey. Just got a Ford 3000 with a front end loader. Has a pump in the front. It's extremely sensitive.just touching the lever will raise a lower it at full speed. It's basically impossible to move it slowly.
How can i fix this?
mine is the same way you will love it after you get to use it more I would not want to go back to a slow acting loader after 25 years
about the only way to slow it down is
1= go very easy on the controls
2= install a smaller pump
3= plumb in a adjustable flow divider to bypass some of the pumps flow back to the tank.
Option 3 takes a little more work and plumbing but allows one to adjust the loaders operating speed to their liking.
I recently converted my 4500 to use a quick attach Farm Hand loader, the factory 25 gpm pump was to big for the loader so I installed a adjustable flow divider to control loader speed.
Flow divider and plumbing cost less than $300, 12 gpm pump that fit the tractor was $975.
Check your pump size, most farm and light industrial loaders are designed to operate on 8-12 gpm, 15-25 gpm for heavy industrial and back hoes.
I put restricter valves in the hydraulic lines, and it didnt work for me, apparently I put them in the
wrong place?
(quoted from post at 16:20:26 02/26/17) I put restricter valves in the hydraulic lines, and it didnt work for me, apparently I put them in the
wrong place?
It's not a good idea to put restrictors in a open center hydraulic system. These have positive displacement pumps, when you fully open the valve fluid flowing against a restriction will cause a pressure spike forcing the pressure relief valve open to bleed off excess pressure. This is hard on the pump, loader valve seals, lines and relief valve.
Restrictors are designed for closed center hydraulic systems with variable displacement pumps that only pump as much fluid as flow allows.
