Ok, got a chance to put my new to me 1968 Ford 3000 gasser to work over the weekend. Yes, that inline 'thing' is a replacement fuel pump. It's a Carter Carotor which you can see here: http://carterfuelsystems.com/fuelpumps/universal_fp.php. Mine looks just like that with the filter and everything.
Well, after it got good and warm bush hogging it would start to die quickly for several revolutions and then kick a bunch of black smoke out of the stack and fire back up and keep going for a few seconds or minutes and do it again. It only did this at higher RPM's but that's where I needed to be to power the bush hog. At medium and slow speeds it would run great and smooth. It would only 'stumble' like that at higher RPM's. Only a couple of times did I have to step on the clutch to keep it from dying all the way.
I don't have a choke cable on it to use in those situations to see if it was rich or lean. I've pulled the line from the tank to the carb (filter and pump) in order to put the choke cable back on. I'm thinking of going back to the stock fuel pump but hear that they are in a touch place to work on. Anyone have any suggestions? I know I need to check all the filters. Haven't done that yet. Anyone have any experience with one of these? I think the number is: 2M04A 430 I can't find any reference to it. I'm open to any and all input. Thanks.
