Hi all, I have a 3000 gas 8 speed with a live (2 position clutch) PTO that doesn't work. Depressing the clutch pedal all the way doesn't allow the PTO lever to engage the clutch. Just grinds if you try.
I've adjusted the pedal per IT manual: Pedal pushrod link pin is in the rearmost (upper) hole. Pedal non-free play is 9-1/2" Pedal free play is 1-1/2" more.
I've tried one online suggestion of depressing the clutch fully and lowering an engaged running brush hog into some thick stuff to "break loose" the PTO. No go so far.
I have also watched the Gingel youtube video on replacing a standard looking two stage clutch and pressure plate combo.
I'm kind of confused about the PTO clutch as a result. Is the PTO just driven by the regular 11' transmission clutch plate or is it a separate clutch made up of a bunch of disks?
The IT manual shows a separate PTO clutch with disks, but the Gingel video seems to be saying that PTO clutching problems can be solved by replacing or adjusting the main transmission clutch.
On my tractor the main driving clutch seems to work fine. And the clutch point and pedal free travel seem normal.
So -- is it 2 clutches or one? And any suggestions?
