Ford 3000 gear issue
Cbass91120
I have a ford 3000 diesel, it runs and functions great. The issue I have is it is way to fast. First gear is no where near a crawl gear. First gear is too fast to operate certain implements such as a tiller. It works great with a bush hog in 1st or second but anything after that is just not necessary. The story I have on it was the wheel base was narrowed in order to go in between rows in an apple orchard a long time ago but I don’t have another 3000 to go off for reference . I really don’t have any problem with the tractor other than it is geared to high. Does anyone have any suggestions? I looked at replacing the gear cluster but I’d hate to spend that money and maintenance for the same result.
What transmission does it have?
The straight up 4 speed is very fast.
The 8 speed (4x2), 6 speed (3x2) and Select O Speed transmissions were quite a bit slower.
Find and list the model codes stamped into the transmission housing behind where the starter mounts
On some models with small rear tires and 8 spd transmission Ford used the gears from a 4000 in the transmission when this setup is used on a model with standard tires sizes the tractor will be geared to run 25-30 mph at road speed
