Ford 3000 Hydraulic Failure
The hydraulic pump on my 3000 is gushing fluid when the tractor is running. It failed when I was trying to pull an auger out of the ground. Is there a rebuild kit I can use to repair this issue? Any advice would be greatly appreciated.
Thanks,
Sam
I am assuming that I need to remove the pump from the tractor and take it apart to get a better look. Here are some questions:
Do I need to drain all the hydraulic fluids first?
How can I identify which rebuild kit I need? Is there a way to get a model off the pump?
Are there other mechanical parts I should replace when I have it apart just for good measure?
I am sorry if these are dumb questions. I really appreciate all the help you guys give me on this forum.
Sam
