Ford 3000 Hydraulic question
buckeye021
I have a '68 Ford 3000 (gas) and I am wanting to hook up a Fasco 1200 loader, as others have done on some other threads. I am trying to figure out what the controls are for in the attached picture, so I can can figure out what I need to do to run the loader. I want to be able to operate my rear lift arms while using the loader, so if I need some other block or controller, that is okay. The loader has single action cylinders on the sides, and a single double acting cylinder on the bucket.
-What kind of controller do I already have?
-What do I need to add (or replace) to run the loader?
Thanks guys
Thanks. I assume you mean I can only operate the lift or the bucket, so the rear hydraulic will still work? In other words, I can have a blade on the back, lifted up, and still use the end loader?
Is there a part(s) I can install to allow for simultaneous use of the lift and bucket? Even if that means removing the Gannon valve. I have heard of others installing a power beyond, which if I google that for a Ford 3000, the first thing that comes up is this, from this site:
https://www.yesterdaystractors.com/HV4902_Hydraulic-Adapter-Kit_10640.htm?gclid=Cj0KCQjwz96WBhC8ARIsAATR252DddBNThBPM1Mn66oPdZFUYtShFlj3W1s1B8Q5rwiVS-zhoLCTjeIaAh2XEALw_wcB
And then could I install something like this:
https://www.amazon.com/Monoblock-Hydraulic-Directional-Control-Single/dp/B07X2LZH4C/ref=sr_1_20?crid=QKLU67XCGAL7&keywords=two+spool+hydraulic+valve&qid=1658347118&sprefix=two+spool+%2Caps%2C651&sr=8-20&ufe=app_do%3Aamzn1.fos.d977788f-1483-4f76-90a3-786e4cdc8f10 ???
When either of those valve handles is doing work, then the 3 point will not be responsive, but it will operate when those 2 handles are centered. The 3 point will hold a load up once it is up no matter what you do with those handles, as long as there is no internal leak in the 3 point system.
