Ford 3000 Instrument Cluster problem
taylor74
Ford 3000, 1966, 3 cyl, gas: The tractor is clean with no rust and runs great. Of the 5 indicators in the Instrument Cluster, ONLY the generator light
works. The oil light, temperature gauge, fuel gauge and tachometer do not work. I want to get these indicators performing again. Any idea if there is
a common denominator causing the 4 indicators to not work while the generator light works normally? How would I diagnose this problem?
Thanks for any help!
Dave
here's a wiring diagram to go by
Dave,
There is no common denominator for all your problems. The 3 amp fuse that Bern refers to powers the oil and generator lights. If your gen light works, we can assume that fuse is good. The oil pressure light gets its ground from the low oil pressure switch located on the engine. Possible bad bulb, open wire to the switch or faulty pressure switch.(oil pressure opens the switch and the light goes out) Easy trouble shooting with a volt meter. The temp and fuel quantity gauges receive their power through the voltage stabilizer, which also receives its power through that 3 amp fuse. Check for power to and from stabilizer. If you have voltage, the problem is most likely the sending units. (my fuel sending unit had a float that developed a hole and stayed at the bottom, I replaced the temp sender and it works now) Your tachometer is cable driven off the generator. Disconnect the cable at the cluster and with the engine running see if it's spinning. I would do the voltage checks with the engine running.
KV Bruce, thanks for the reply and the very good information. I appreciate your detailed response. I did a lot of research last night and determined that the Oil Warning Lamp is a simple, straightforward connection and that the 3 amp fuse was not likely the problem. I opened the Instrument Cluster today and found the the Oil light bulb was broken. I also found a broken wire with the connector end attached to the Voltage Stabilizer for the Fuel Gauge. I cleaned all connectors with CRC and installed a new bulb. I spliced the wire to the Fuel Voltage Stabilizer and crimped on a blade connector and hooked it up. However, one of the blades on the Voltage Stabilizer was not being used at all. Also, there is a blade connector on the Fuel Sender Unit that had nothing connected to it.
Verdict: The Oil Warning Light now works perfectly. The Fuel Gauge does not work. I have to do more research and study the wiring diagram but does anyone know if there is supposed to be a connecting wire from the Fuel Voltage Stabilizer to the Fuel Sending Unit?
I didn't yet mess with the Proofmeter or the Temperature Gauge.
Thanks!
The gen light can come on if the 3-amp fuse is blown. This is because the key switch powers it on one side, and the generator powers it on the other side to extinguish it in normal operation. If there is no power on the key switch side due to a blown fuse, and the generator is in fact charging, the light will be on. I should have made that clear in my first post.
(quoted from post at 21:13:32 01/20/20) The gen light can come on if the 3-amp fuse is blown. This is because the key switch powers it on one side, and the generator powers it on the other side to extinguish it in normal operation. If there is no power on the key switch side due to a blown fuse, and the generator is in fact charging, the light will be on. I should have made that clear in my first post.
Bern, rethink that... if the fuse is blown there is no way for current to flow and so the bulb could never illuminate.
I guess it could light up if the voltage from the "WL" terminal on the VR were to somehow backfeed through the voltage stabilizer and then through the gauges to their sending units to ground, but at that point the bulb would be very dim and probably flickering due to the opening and closing of the contacts in the stabilizer, and the gauges would probably deflect at least some.
I stand by my original statement. If the 3-amp fuse were to blow, that side of the circuit becomes the
ground path for the generator lamp bulb when the engine is running. This current will flow straight through
the closed voltage stabilizer contacts (which will never open - hence no flickering) and on through the
gauge coils to ground. One small bulb would not conduct nearly enough current to deflect the gauges,
especially when you consider the fact that it's grounding through both gauges in parallel.
(quoted from post at 22:25:41 01/20/20) I stand by my original statement. If the 3-amp fuse were to blow, that side of the circuit becomes the
'm not always with you, but on this one, I agree with you.
OK, I've thought about it some more, and your logic does make sense but the bulb would be very faint. If the current was not enough for the voltage stabilizer points to get hot enough to switch off and on, then the filament in the bulb would not be getting hot enough to emit much light either.
The Generator light and Oil Pressure light are now both working normally. So I don't think the fuse could be blown.
How do I test the Voltage Stabilizer with the multimeter? It feeds the Fuel Gauge and Temp Gauge but they still do not work. There is no wire running
from the Voltage Stabilizer to the Fuel Sending Unit. (photo attached) I find that strange.
(quoted from post at 21:03:27 01/20/20)
Yes, if the fuse is blown and then genny is providing power on the other leg of the bulb,,,,, the generator bulb will simply look for a current path to ground through the other connections on the fuse side,,,,such as the voltage stabilizer, So question is... will there be enough current to actually make the bulb light up brite enough to see it going through the stabilizer, then the fuel and gas gauges to ground.
There should be no wires directly from the voltage stabilizer to either sending unit. There should only be wires from the stabilizer to one side of each gauge. The other side of each gauge should have a wire go to its sending unit, which completes the path to ground though a variable resistance in the sender itself, and the varying current through the varying resistance controls how far the needles in the gauges deflect. The fuel sender's resistance varies depending on the height of the float and temperature sender's resistance varies depending on the temperature.
Not easy to test the voltage stabilizer with a digital multimeter. The numbers on the display would be constantly changing. The stabilizer works by opening and closing internal contacts rapidly so that the average output is reduced form the incoming 12 volts to approximately 6 volts at its output. An old analog style volt meter would be better, although the needle would bounce a little but it should average right around 5.5 to 6 volts. You could see it on an oscilloscope as a square wave with the peaks being +12 volts when the contacts are closed and zero when they are open and then look at the timing of the pulses to see if they are averaging the off and on portions of the wave each being about 50% of the time.
Thanks, Sean. Very good information. I'm not sure how to test the Voltage Stabilizer but I do have an analog meter also so I'll give it a try.
