I got a 1968 Ford 3000 gasser last year but this is the first time I’ve had a chance to put it under a good load. I went through it when I first got it replacing fluids and adjusting things. It only got used a few hours bush hogging and such. Yesterday and today I was pulling a Ford 2-14 plow through this heavy clay soil up here on my ridge. The first hour yesterday went great. Lots of power and smooth. Then under load I started losing power. It wasn’t firing on all cylinders. It got to the point that from a dead stop I couldn’t let the clutch out and get rolling even with the plow up. It was missing so bad it died. I tried restarting it and all I got was a ‘click’.
I opened the hood and a simple touch of the positive battery cable showed it was loose. I had run as far as I could since it wasn’t charging the battery. I have the original generator and all the original ignition components. (I do have an electric fuel pump.) So, I hooked up the trickle charger and let it sit last night. I went out and fired it up this morning and it ran great. About an hour in it started doing the same thing. I quickly checked the battery cables and they were fine. The generator was putting almost 16 volts to the battery.
I was able to finish my plowing since it didn’t get as bad as the day before. But under load it was missing. When it wasn’t under load it was smooth and firing on all cylinders. I’m thinking the coil might be getting hot and start getting intermittent. But, before throwing parts at it – and since I have to run it for an hour before I can get it to do it again – how should I diagnose this? Thanks for the help.
