I have a 1968 (?) Ford 3000 with front loader that I just purchased. I noticed te power steering was not woring but decided to take a chance on it. I checked the fluid and it was quite low. Still did not work after adding fluid. I discovered that with the front wheels off the ground it steered very well with te engine off. When running it is extremely difficult to turn the wheels. It feels like the right and left is fighting against each other. I noticed a newer cylinder had been put on the right side, so thinking the lines might have been reversed, I reversed the lines. When the tractor was started the steering went from right to left continuously very rapidly. I believe the pump is working to have this kind of force. I reversed the lines back to where they were.
Is there an adjustment or directional valve somewhere that needs adjusted or replaced. Help would be appreciated. Thanks, Sherman
