FORD 3000 Wheel Weights
Have some donut wheel weights that appear that they will need to bolt on through round holes (3) through dished hubs, which seem to line up on both pieces. Any tips regarding what type/size fasteners, install or any ideas greatly appreciated.
The biggest bolt that will go through the hole. Then measure the wieght thickness and ad about an inch to inch and a half to that for nut dish nd a washer if needed.
Besides figuring out what size bolt to fit the hole I
suggest cutting some all-thread to length and welding a
nut to the end if you have more than one weight to stack
on. This allows you to just slip them on vs trying to bolt
one weight to another.
The weights have two sets of equally spaced three hole mounting configurations. One set is flush mount and one set has an indent into a half circle. Does it matter which are used to flush mount to a smooth rim surface?
