Msboy
Hello everyone I purchased a ford 3000. It has 2k hours on it and I Recently put a new clutch in it and the hydraulic are not lifting so I put some shop air to the full level port and the hydraulic begin to lift. But after a couple of days. The hydraulics stop lifting and I have to repeat the air process. Does anyone know if the hydraulic system on these ford 3000 are pressurized system?
Sounds like you have an air leak on the suction side of your pump. It could be as simple as a cut or damaged o-ring on the inlet tube at the pump.
