I have a Ford 3000 gasoline tractor. Before draining and adding fresh transmission-hydraulic fluid, the transmission shifted smoothly in all gears. However, after changing the fluid, it is very difficult to put the transmission into any gear of the high or low ranges when the engine is cold. However, after forcing the transmission into a gear and driving for about 5 minutes, the transmission shifts smoothly. I would appreciate any suggestions to correct this situation. thank you.
It sounds like you have 140 weight gearlube in the transmission. I believe the original fluid was 85-90 gearlube in the trans. and Tractor Hydraulic Fluid in the hydraulic system. If the front tranny seal is good, many people do fine with Tractor Hydraulic Fluid in the trans. also.
What oil did you put in it?
80W90 would be acceptable, but 134D is recomended, especially in cold weather.
Rod
