(quoted from post at 15:40:23 06/29/12)
(quoted from post at 22:18:29 06/28/12)
(quoted from post at 18:17:27 06/28/12) that plug onthe top option cover would tell all..
Can you please tell me what to check for to solve my problem?
There is a 3x5 plate on top of the center housing between your legs when you're sitting on the tractor. On that plate there will be 1 bolt head that is larger than the rest. Remove that bolt and install a 3000 psi liquid filled hydraulic pressure gauge and then start the tractor. Correct pressure should be at least 1700 psi, and best would be up around 2200 psi.
That port is right after the pump in the hydraulic circuit, and before the 3 point lift control valve.
If the pressure is ok at that test port when you first start the tractor, and the lift is still having problems until it warms up, then the problem is somewhere in the lift mechanism. Either in the control valve, relief valve, unloader valve or lift cylinder.
If the pressure is not ok at that test port until it warms up, then the problem is in the pump side of the circuit, either with the pump itself or a leak at the suction tube as sounNdguy said.
