Ford 3400 Fuel Pump
ddzurik
Ford 3400 Fuel pump on 3 cyl gas engine is bad and previous owner took off fuel lines and ran
hose from the tank to the carb. I am replacing
pump with an electric model with a pressure regulator. Does anyone know the pressure of the stock fuel pump? I am guessing about 1 1/2 psi.
Does that tractor have The Holley Carb on it?
If you have a poor running gasser with a Holley, getting fuel to your carb maybe not be the only issue.
I couldn't tell you what the pressure is supposed to be. Get a pump and an adjustable regulator. Start low and if the tractor stumbles under load increase it. Dunno.
If the lines are still going to the original pump I would pull the rad, replace the pump and use that venerable but adequate system.
On the other hand, an electric pump and filter mounted under the tank by the steering column, covered up by the steering tins (if you still got them)would be a nifty way to deliver fuel to the carb. Use metal lines.
You do know that there is a screen in the petcock at the bottom of the tank that can plug, one inside the original fuel pump, one behind the carb in a sediment bowl and one more screen into the carb itself.
Is the tank rusty?
Sorry so long.
I think 3 lbs stands out as for small engines and generators. The pump is used on gas engines more so to stop it from vapor locking and to help it on slopes and hills.
Time you get done dicking around with all that, you could have bought & installed the correct mechanical pump (OEM or aftermarket) and been done.
Ordinarily I would agree with you.
But if the lines are missing consider all the bending, clamping and flaring you'd have to do from the tank to the oem pump then back through a filter/sediment bowl (which is NLA)to the carb.
In that case a tidy electric setup hidden behind the steering tins might be the way to go.
