Ford 3400 Hydralics
Tiber56
I replaced the shaft and seal on my vane type front pump for the 730 loader. The pump was working tell the splines on the shaft and hub stripped. After putting everything back together I filled the tank with fluid. I cracked the out put side of the pump tell fluid ran out. I started the tractor and tried the hydraulics and got no movement not even a jerk. The rear 3 point does not work now. Any one have any ideas?
The front pump does not power the 3 pt., only the loader, and backhoe if so equipped. The 3 pt. runs off the pump on the rear of the camshaft. Is your machine equipped with a selector valve attached to the front of the lift cover housing?
