Ford 3400 with 730 loader
Tiber56
I have a vane type hyd pump for my 730 loader that I replaced the spline shaft,seal and bearing. I took pictures as I disassembled it to guide me in reassembling it. Back together and filled with fluid. I cracked the out put line and I have fluid to that point. I get no response. I did get a belch back through the breather one time. Any guidance would be appreciated.
No sure about the pump you have but on some vane pumps if you turn the center body around it'll pump in the other direction.
Are you sure you got it back together exactly like it came apart.
