Ford 3400Need
Tiber56
Need help in ID ing the front end loader on my Ford 3400. Pictures attached. I need a new hydrulic pump as the splines are stripped on mine.
(reply to post at 05:15:37 09/19/18)
hank you. Does your loader pump have the inlet and outlet on a horizontal plane and a somewhat egg shaped flange on a vertical plane. My pump is square and is 3 layers. I have not been able to locate any numbers on it. When I tried to order a pump the number we came up with for a 730 loader is for a pump with the inlet, outlet and flange on a horizontal plane.
Also, I believe when it's time to replace a vane pump on a 730 loader a similar-spec gear pump is substituted and the hydraulic plumbing adapted. The most common substituted pump seems to be a Cross 50P027LBASB.
(reply to post at 18:02:45 09/17/18)
hank you. Is Thera place that is best to bleed the system. I replaced the shaft,seal and bearing in the vane type pump and loosened the out put line and I am not getting any movement.
(reply to post at 18:08:59 09/19/18)
hank you for the help. I was able to get the parts to rebuild my pump. I replaced th shaft, seal and bearing. I cracked the out put line tell fluid was flowing. Started the tractor and no response in the hydraulic system.
