maxims45
- Location
- Ann Arbor, MI
Hi there! Could the community please guide me in the right direction regarding what to explore?
1968 Ford 3500 with a 3-cylinder gas engine, 192 engine block, 4-speed transmission, 540 PTO. 6000 hours and was sitting in the field for two years.
A winter project in my garage, replaced oil 15w40, filters, oil pressure sensors, wiring, instruments / tach wire, fixed the electrics, VR, generator brushes, tires. Just going through.
The video of the engine noise is attached. The noise is coming from the top front of the engine, 2 minutes after a cold start at 800 - 1000 rpm. The oil pressure lamp lights up and goes away as expected at startup. At 1200 rpm, the noise is too loud to hear. Doesn't go away as the engine warms up. Not fan-to-shroud contact... Not sure if the clanking was there before the oil change, and it somewhat comes and goes.
Before opening it open, wanted to tap into others expertise on what to check! Thanks in advance!
[video play=false:babc83830e]https://forums.yesterdaystractors.com/videos/mvvideo112505.mp4[/video:babc83830e]
