Hello everyone I would appreciate some input.
Working on a Ford 3600 I got from my grandpa, cluster wasn't working besides tach and battery light.
I ordered a new instrument cluster and pulled the old here is what I found.
Old cluster had the main power wire and fuel sending wire almost completely chewed through; I patched those up.
I have traced down the wire for engine temp (black), there is a green wire that came into the back left of my old panel near the hot wire; it's terminal does not ground to the cluster but possible a ground back for hot coming in (need verify later today)
To my surprise my old cluster had 6 small dummy bulbs as well in the harness but only 4 dummy bulb locations on the cluster (I think two are unused possibly for larger model tractor cluster).
Like I mentioned only a light for battery was working before. You turn the key and get a light and when running light goes out (What I found strange was I can read voltage on that light socket with tractor running, but bulb isn't lit up not sure how its goes on and off from key switch on to tractor running still having voltage running?)
Can anyone confirm from me what the factory dummy lights are? from Left to right on cluster looks like I have battery indictor (I think on when no charge); one is a down arrow (no idea what it is), 3rd has no picture (new clusters is left/right arrow), 4th I think is oil pressure.
I think I'll be fine with my tach, temp gauge and Oil pressure I want to understand where oil pressure is sensed for my learning, but it still had those other lights that I'm not sure what they indicate and while I'm in here I'd like to just fix restore them all if possible.
Appreciate any input and guidance you could give me.
Here is the new cluster
https://www.yesterdaystractors.com/E5NN10849BA_Instrument-Cluster_508.htm?gclid=CjwKCAjwgaeYBhBAEiwAvMgp2kjmWDkNY8-3CngkbWLA-wnC7NpztFCuObFiZ9UA1S1WHvDF1jlQpRoCCDcQAvD_BwE
This post was edited by Luke0927 on 08/27/2022 at 03:43 am.
