I just brought home a 1963 Ford 4000 and I'm having a few problems with it.
It fired up instantly without the choke, even cold. But whenever there's a load on it you can hear it pinging. It will also diesel about 75% of the time when shut off. The idle on it is about 900 RPM. When increasing the throttle from idle it will die unless it is done VERY gently.
I did a little bit of tweaking on it, the manual calls for 4 degrees BTDC. It does not have a vacuum advance, so nothing to unplug when I'm timing it. I played with the timing and was able to get it to smoothly rev up without killing it, but the timing ended up at around 30 degrees BTDC!!
I set it back down to around 5 degrees, and started tweaking the carb. Based on a few things I read from here. I have the idle speed down to around 450 now, and it will start reliably. I still have that massive dead spot when I try and throttle up from idle though. Timing light shows it at 20 BTDC when running at 2000RPM, so it is advancing. I believe the manual calls for 25 degrees though?
The carburetor has 3 adjustments that I can see. An idle speed screw on the throttle, a screw on top of the carb at the front, and a big T handle screw at the bottom just in front of the drain on the bowl.
As I understand it the small screw on top is the idle air screw, and the big T handle screw on bottom is the load/power screw?
I'm going by this thread here: http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=21690
Am I understanding it right and the big screw referred to is the big T handle on the bottom of the bowl?
How should I go about tuning this?
