Ford 4000 (gas) separation
I need to separate the engine from the transmission on my Ford 4000 to replace the ring gear on the flywheel. I would appreciate receiving any guidance on the best approach to doing this.
thanks, Doug Campbell
Very carefully support the front of the tractor with cribbing etc. up to the oil pan rail and not the pan. Get a good rolling floor jack under the trans and roll the rear away from the front. Remember that the front will pivot at the axle so make sure you support it so it cant tip. The rest is pretty self evident, like the steering and such. Have fun!
