Ford 4000 hydraulics
MAJK
Hello, i have a following problem with my ford 4000. The 3pt hitch is lacking power sometimes. Sometimes it has enough strenght even to lift the nose up, and sometimes it only slighty makes the nose lighter. Same time when the 3pt is lacking its lifting power the remote hydraulics stop working correctly. I have hydraulic push bar and it moves only little bit when 3pt stops lifting.
Has the hydraulic pump gone bad or some valve clinging or leaking?
My hydraulic pump is in rear.
It could be a number of different things. My first thought is that the brakes and/or PTO clutch material might have deteriorated and fibers are floating around in the sump and sometimes clog the intake screen.
A 3 cyl 4000is either side of 55 years old. The pump is aluminum. Been dead headed numerous times There is a screen that maybe stopped up that bolts to pump. If unit has not been repainted and pump housing is
blue its still got original pump.
The pump has been changed at some point because its not blue anymore. Or atleast i think so. Today i will measure hydraulic pressures.I also think that there might be something that clogs something on the hydraulic system.
My 4000 has it s original 69 model pump, it is getting weak and has become rpm sensitive
Below 1000 rpm it doesn t have much lifting power, 1000-1200 rpm it has moderate lifting power but is a bit slow, above 1400 rpm it has good lifting power but is still slower than it was years ago
When you notice the lost of lifting power are you running at a lower rpm, if so the suction screen could be partially clogged, otherwise I d suspect a worn pump
FYI the lift and remotes use the same pump and fluid flow, if one is weak or slow so will to other
Now i measured hydraulic pressure, when it was cold it was 170bar and when warm it was a bit less than 170bar. It didnt change much if i was idling or giving revs. Max 5bar was change.
So i think there must be clog somewhere and i need to take the lift cover off.
(quoted from post at 10:26:18 05/31/23) Now i measured hydraulic pressure, when it was cold it was 170bar and when warm it was a bit less than 170bar. It didnt change much if i was idling or giving revs. Max 5bar was change.
Were you taking your measurements when it was working properly or when it was exhibiting the problem? If it was working properly, test the pressure again when it is exhibiting the problem.
(quoted from post at 09:54:03 05/31/23)
When i measured it was working properly. Maybe i have to take new measurements with load on 3pt and when it stops working properly take new measurements.
Okay, now i tested the pressure of hydraulic system while under load. It was still pushing 170bar and the nose got only slightly lighter. And the push bar that uses remote hydraulic only moved in or out about 1inch or 2cm and did nothing else
This post was edited by MAJK on 06/01/2023 at 08:24 am.
