Ford 4000 industrial
Hello. I have a ford 4000 industrial that has the vane style
hydraulic pump mounted on left side of the motor. Can anyone
point me in right direction as far as where or part numbers for
the 2 o ring gaskets that go between the transmission and the
hydraulic manifold? Thanks for the help
I assume that this is a 4 cylinder 4000, correct? If so, it should have a piston pump, and the pump should be on the right side of the engine.
The part numbers for the o-rings are C0NNB998A and 47697560.
Yes sorry I'm a bone head. Yes it's a 4 cylinder and The pump
is on the right. My mind must have been thinking backwards.
Anyway. Thank you for info
