Ford 4000 info needed
I just bought a Ford 4000. The are 2 numbers stamped on the casing. The top number is 41202 and the lower number with a diamond shape at each end of the number and the number is 23636. What do these number tell you? It is the older body style like the 801's. What is the horse power? Thanks, jack
The first mnumber is the model number. The second number is the serial number.
It's about 48 PTO HP if gasoline, and about 43 if diesel.
Dean
If it is a 4 cyl it's the same as a 801 841 etc. If it is a 4 cyl and has a shifter that has Neutral up and down, and 5 speeds it has a two stage clutch. If it is a 3 cyl i'm sure it has independent pto also.
