I purchased my tractor to work on our dirt road to my home. It is about 10 homes along the road, maybe 1 mile one way. A neighbor had an old tractor with box blade that I use to work with, the box blade could adjusted to tilt to get a "kinda" crown in the middle of the road. His transmission went out and it was never repaired, later sold. It has been a few years and holes have gotten big and deep. I got a 6' box blade to work with, I noticed the leveling arms on the tractor cannot be adjusted. I checked here at YDT, talked to Dave about what I needed, he told me to measure the existing one on the left. I did the measure and it is 30 1/4 inch. Talking to Dave this morning he said I would need Part C5NN569AM for the right side, as it is 27 1/4 to 32 1/4 length. So I am thinking that would only be 2 inch or if I when the other way 3 inch. Which would not be very much of a pitch .... to me anyway. So I mentioned that to Dave and ask should I get a new one for the left side - Part E0NNB484DA - Rod Leveling that is 27 1/2 to 32 inch. That way I could adjust it down to 27 inch and the right side to 32 inch giving me 5 inch pitch. Dave said that would work too. He said that part will adjust but it has to be disconnect from the tractor to adjust. I remembered seeing threads on the one on the right side, but did not see how it could be adjusted... not thinking about disconnecting from the tractor. It would be too much trouble to remove it each time to adjust. So I said all that to ask this, can I take the existing one on the right side, put it on the left side after adjusting it to the shorter length, it is 30 inch now. Then buy the new Part C5NN569AM with the crank for the right side. If the old one moved to the left side does not work like I hope it will then I could buy the Part E0NNB484DA as talked about.
I really don't remember what length the rods were on the other box blade I used, it has been a few years. So if I am incorrect about how much pitch is needed, Please advise. Also are there problems with putting the left side to 27". I have include a picture of the hitch and close up of the existing right side with threads.
Open For Suggestions... Thanks
Michael
Michael
