I have a 1964 Ford 4000 LCG with the SOS transmission that has some PTO issues. I took it to the local mechanic and he found some metal shavings in the “sump”. The PTO used to free spin (spin with engine rpm) but would never fully engage. After changing fluids (mechanic) says PTO will not spin at all. You can still spin by hand but it does nothing with engine rpm and pull switch engaged. He says that he thinks it’s the PTO clutch but shouldn’t it still spin even if the clutch is worn? Trying to figure something out before I go spend another ~$1000 on a rear end that isn’t a SOS. Thanks!
