I have a Ford 4000 SU 3 cylinder gas, it has been a little cold natured since I got it but the other day it just died. It will crank with the choke pulled out and the throttle in idle position and it will
just purr like a kitten in that position. but if you push in the choke or pull down on the throttle it dies. my first thought was fuel delivery so I cleaned everything lines, pump, carb, filter, sediment
bowl. Did not change a thing. so I bought a standard carb rebuild kit and a new fuel pump and did that - still the same thing. Any thoughts?
