Zenith will also fit.
If you can find a rebuilt original cast iron one, it will be better than an aftermarket aluminum knockoff. Watch the linkage, compare it closely to the original. If any difference the governor link will need to be adjusted. Keep the Holley for reference until you get the new one in place and working.
I agree, that Holley is terrible! Not often one defeats me, but those have!
Bite the bullet and buy the Real Zenith for $500 not the China made zenith knockoff for $200. I have replaced several Holleys with Zeniths over the years. They are an exact swap and work excellent.
I have a 3000 Holley with a brass piston type accelerator pump a 4000 with a Holley that has a diaphragm type. The 4000 ran bad after several tries to fix it I finally left the diaphragm out and put several pieces of masking tape in its place. Also blocked the vacuum hole with sealer just experimenting. The tractor runs perfect and is still going just fine. Get rid of the pump ant block all passages to it and see what happens.
