I finally got that 4000 moved yesterday. After about 30 mins of tinkering we actually got it to start and drove it back and forth a few times.
(It has set up for 20+ years, so once I tried to turn the wheel, the high pressure hose going to the steering cylinder busted.)
I don"t have much experience with tractors and just had a few questions. First, the PTO was spinning with the clutch disengaged. Does this mean the PTO is independent? If so, how does this differ from a transmission PTO? Anything I need to know about operating it or just use it the same as a transmission driven PTO?
Second, there is a pedal on the right side behind my foot. I pressed it a few times and nothing noticeable happened, anyone know what this is for?
The tractor is a 3 cyl. diesel. Not sure of year as the transmission was replaced and now there is no serial number.
I believe most 3-cyl. 4000's have independant PTO (those with 8-speeds and SOS's, anyway) They have their own, hydralically operated clutch. Can be engaged or disengaged without using the foot clutch. SOS models don't have a PTO brake, if an 8-speed, it may need a new PTO brake.
The pedal by your right heel is the differential lock. Don't use it when trying to turn, or you won't be ABLE to turn. :) Just sitting there, or going straight (and not spinning), you wouldn't notice anything when you step on it.
