ford 4400 cav injection pump
snead
Can someone give me instructions in how to remove and install the fuel injection pump on my 1974 ford 4400 diesel tractor :?:
It can be done without setting crankshaft, just make a note where the pump flange scribe mark is next to the timing case mark now. The drive gear cover needs removed to
remove the three gear bolts that thread into the pump drive hub. There's a gear pin that aligns with the hub notch when installing the pump. Remove lines and control
connections as needed, then the three bolts holding pump to timing case and remove pump. Starter does not need removed, while it's close pump will clear the starter.
