Ford 445A Hydraulic Pump Leak
Tweeter
Trying to identify a leak on a Ford 445A front mount hydraulic pump. Reservoir is low and oil is noticeable all over the front axle. Where are leak prone areas to look for in this system?
Pump seal, then the rubber hose from the tank outlet to the pump.
Raise and lock the loader, then take out the 4 bolts holding the grill in, you can view almost everything from here
