The 3rd function valve will get tied into the electrical system.
(quoted from post at 20:39:58 03/17/22) The third function valve uses a solenoid. Needs 12 volts to work. On most it has a rocker switch built into a handle that goes onto the loader control handle.
(quoted from post at 15:21:08 03/19/22) Due to age of machine, It would be difficult to find a power beyond for that valve.. OR , it already has one to operate a backhoe.. You can't add
another function if the power beyond is already being used.. What I would suggest is to get a separate single spool valve with ample capacity [
25 to 30 GPM] with a power beyond sleeve in it. Hose your feed from the pump to the single spool valve inlet. then hose from the power beyond out
let to your main loader control valve. That system is an open center hydraulic circuit. Meaning that oil must flow at all times unless a function
is selected. Then oil flow stops or slows to operate any given circuit. If you Tee a valve into the circuit , one valve will flow oil to sump
when you try to operate the other valve. The only way that will work is on a closed center hydraulic system [ piston pump]..
