Ford 4500 backhoe
Dennis W
Tried to bleed 3cyl ford diesel.Followed manual instructions . Bled top of filter, injection pump, lines at injectors. Very little fuel pressure on 1,2 cylinder. Number 3 had much higher pressure could hear it trying to fire.Did this cycle 2 or three times .Same responce. Wont start. Any ideas where to go from here???
I've run mine dry numerous times. When cracking the lines at the injectors to bleed, most people make the same mistake. Crank the engine at WOT while doing this. If done with
throttle closed there is no flow.
WOT was used, checked stop cable , made sure it wasnt stuck. It would just about start when #3 injector was cracked open. Is there an easier way of bleeding the system without frying the starter and battery from constant cranking.
I have applied pressure to the tank. It
seems to help or at least it makes you feel
like you did something. There is a port on
the back side of the pump with a 5/8 head
on it to let it fill. Keep trying! They are
the hardest diesel to get started that I
have ever seen! I always hook jumper cables
to it to save the battery. Just do short
trys and don't get the starter hot.
Thanks guy all the advise was excellent.Used a remote starter bled the lines ,as you suggested giving the starter a rest between
bleeds,WOT, boosted battery, second time through she started. Yes this old girl is fun to start,especially when the operator forgets to turn
on the fuel supply . Alzheimers
