ford 4500 trans question
Hi
I have a 1970 Ford loader backhoe with the torque converter auto reversing transmission. It will move when its cold but after the
oil seems to warm up it stops moving, then let it sit and it will go again, any thoughts? Every thing else is fine all the
hydraulics work as they should. Thanks
The hydraulics on that tractor have nothing to do with the transmission. The loader and backhoe run off of a hydraulic pump up on the nose of the tractor and use a reservoir up above the radiator. The transmission is its own reservoir with the fluid inside the transmission itself, and the hydraulic pump for the trans is also inside the transmission.
It sounds to me like the pump inside the transmission is worn, or the seals in the forward/revers clutch circuit are bad, or both, so that it builds enough pressure to work when the fluid is cold but, when it warms up and the fluid thins out, then not so much.
If you have nothing to lose, but a major overhaul, what if you change hydraulic fluid to a higher viscosity? Maybe to a different type of oil with a higher viscosity. I think I would be inclined to look into that considering that I work alone and a 4500 has some heavy parts for a guy to manage working alone. If I would have to change out a major component anyway, so what if the different oil makes things worse?
(quoted from post at 12:16:04 11/27/23) If you have nothing to lose, but a major overhaul, what if you change hydraulic fluid to a higher viscosity? Maybe to a different type of oil with a higher viscosity. I think I would be inclined to look into that considering that I work alone and a 4500 has some heavy parts for a guy to manage working alone. If I would have to change out a major component anyway, so what if the different oil makes things worse?
It needs an oil that has both friction modifiers to work with the wet clutch pack as well as Extreme Pressure (EP) additives to handle the pressure between the mating surfaces of the gears. It also needs to be thin enough to work as a hydraulic fluid to control the clutch pack. I'm not sure if a thicker oil is available with all of the necessary properties. I'm not an oil expert, so maybe someone will chime in that knows for sure.
It might also be that the fluid just needs to be changed. I would try that first, and be sure to use a UTF that says on the label that it meets or exceeds the Ford/New Holland M2C134D specification. If it still has the problem after that, then you might not have any choice other than to split it.
