Mnethercutt
Hello,
I have a Ford 4600 Diesel that I use at work that's giving me some electrical trouble. When I started working the electrical system was all messed up. It had no-start issues that I traced to a shutoff switch behind the battery and bypassed, and the alternator didn't work. We have replaced the alternator and I thought that fixed the problem till the battery died again. I was fiddling around and found the problem: the key switch will only let the battery charge if the switch is in position 2. The owners manual I have says there should only be 3 positions, but my switch has 4. Position 1 is "off", position 2 is where it'll charge, position 3 is "run" I guess but doesn't charge, and position 4 is start. Is this normal for this tractor? If so what's the point of position 3?
Additionally, the joint that the steering arm bolts into is loose and I can't get it to tighten. I've attached 2 pictures below of the joint. Whenever I try and turn the bolt the threads just spin with the bolt. I've tried jamming a pair of pliers in there to try and keep it from spinning to no avail. Any ideas?
And a bonus picture of the tractor in its natural habitat:
