ford 4600 hydraulics
ed cornwall
Hi can anyone help i have a 4600 with front loader every thing is fine untill i select loader using lever under seat then 3 pt linkage drops like a stone i tried removing loader but same problem arises only way i can use loader or tip trailer is to chain linkage up. Cheers ed.
What kind of front-end loader do you have? Do you have the two control levers that are under the seat? Maybe the loader manufacturer can tell you what may cause this, as their service dept. may have encountered it.
Hi the loader and pipe work have been removed now but the arms still drop when aux hydraulics or tip are selected. Cheers ed.
I'm not familiar with a 4600 but I think there's a lever or knob under seat on RH side one switches to correct your problem.
Why don't you post question on the Ford forum on this site?
