Ford 4600 loader hydraulics
pwhitt43
I'm getting ready to install a bucker loader and hydraulic rear remotes on my 4600 and am needing experienced info on the hydraulics set up. What works best ? My rear lift is slow but strong. I've seen those front bolster mounted hydraulic pumps but not familiar with them. I guess I need a power beyond valve also ? Just needing some input on what works best. Thanks Paul
The easiest way would be to get an HV4902 hydraulic adapter plate to power the loader and then stack your remote valve on top of the plate.
A front pump will give you the most
speed, but is more expensive. A power
beyond valve is not needed if you go that
way.
