Johnlatt
The other day while pushing snow with a 1978 Ford 4600 the transmission gear shift stick to 5 year moving way too far but still going into gear with no problem and there is no grinding or any other noises.
Before I remove the cover to take a look inside I would like to have all the parts ready for the repairs.
As anyone ever run into this situation and any suggestions for repairs or parts.
Thank you in advance.
If it did that in 5th it should also do it in 1st right?
There's nothing scary or complicated under the shifter cover so don't hesitate to pull it for a look see.
They do wear out. New cover can be purchased from this site. They sell the gasket too.
nnalert shift cover.
Thanks for the reply Yes does the same with the 1st gear, is there a pin worn out that can be replaced or do any need the all cover assembly.
Pa bought a 4600D brand new in ?78. Had the cover open a few times for the neutral safety. Pretty straight forward. Somewhere I?ve got the original receipt. I believe it was $7500 from Kaeter & Odegard.
There is a pin, replaceable without opening it, but from your description, I dont think thats your problem. The shift lever likes to rotate when the pin is missing.
